[ QUOTE ]
((Pssssst, Doc, what's heel-toe?))
[/ QUOTE ]
mehheh... toe onna brake pedal... heel onna gas... as you start to brake for entry into a turn you want to downshift, so: clutch IN, gearlever to neutral, clutch OUT, rev engine with the heel to match RPM with road speed in the next cog down... WHILE BRAKING with yer toe... clutch back IN and lever to lower cog, clutch OUT and repeat 'till you have the cog appropriate for apex/exit and then put yer boot back inna loud pedal again and cog back up on turn exit (actually you'd wanna be "on it" just past apex). You should be able to keep the maneuver smooooth, so's to keep the car in balance and under control the entire time. Sounds hard and complex, but with practice it all happens in an eyeblink. It will always mystify novice LBC passengers and it prolomgs the life of transmissions and clutches too. Just not necessarily while you're learning. Use Emma to learn it: the older gearboxes are a bit more "frail" and must NEVER be put into first or reverse if the car is even *slightly* rolling. No synchro's on those cogs.
[/ QUOTE ]
