Thanks TOC, I only checked the valve lash. No adjustment made since I have owned this little beast. I just finished the "Oil in Cylinder" compression test. Still get "ZERO" in all 4 holes!! How I did this was, remove one spark plug at a time, Squirted about two teaspoons of 30 weight in the spark plug hole, attached a compression gauge then cranked the engine for about 10 to 15 seconds with the throttle wide open. Still got zero compression on all 4 cylinders. Went back and re-check two of the cylinders with an additional 2 teaspoon of 30 weight and still got the same results. Re-checked my compression gauge with my air compressor and it is working just fine. Just wish my LBC worked as good as the gauge :<(
