mightymidget
Uploaded with ImageShack.us
I really don't like the way I have to run my gas line hoses since the weber carb inlet gas line is on the wrong side og the carb, makes since it should pull from the other side of carb. can I switch it to the other side? nipples appears to be pressed in.
I took this motor out of my Bugeye and installed into my Midget, and the gas line was run down under near the exhaust manifold on the Bugeye which I dislike more than this route. Really trying to find a route away from any heat source.
Whats the best fix?
