I was able to work fulcrum pins in a little bit at a lime, back out, clean out the threads with a brush, work back in. Took about 20 minutes per side but now they spin right in.Once you get them far enough in a 1/2" wrench fitted in the slot will get them all of the way down. Again keep cleaning the swarf out of the threads, backing it off, and all will go in place.
The other trick was taking a fulcrum pin to Lowes and finding a wide bladed screwdriver that really fit down into the slot of the fulcrum pin. Tried 20+ but finally found one with a thin enough blade that I could really put some torque on the fulcrum pin. All of the other screwdrivers in my box would fit the slot but not go all the way to the bottom on the slot.
Need to paint springs and wishbones and reassemble the suspension kit but I'm back on theway to putting Bugsy back on the road. 12 degrees this AM. Don't think I'll be spraying paint in the garage today. Will fiish the rest of the prep work though. Trip to hardware store for some cotter pins and steel nylocks for the springpans. Come on Spring. Bugsy wants out of the garage.
