A good use for Alumaloy?
ChrisS
I've seen the commercials and if what they say is true I should be able to get the engine running again with a propane torch and a file. What are your opinions on this approach?
The following shows the piston after a piece that was wedged in was removed
And some cracks
If I run out or rod I'll just fill in the gaps with the chunks from the oil pan and intake manifold. /ubbthreads/images/graemlins/devilgrin.gif
Man, really ate that up.
That's impressive!
I was thinking super glue myself, or maybe some bondo? /ubbthreads/images/graemlins/devilgrin.gif
It will only be stronger, thicker deck on the top of the pisto n when you are done. Might I suggest a Sawzall to re-cut the ring grooves. Phil
I love it! Sawzall ring groove tool!! YEEha!
Let us know how that Alumaloy patch works fer ya, Chris. /ubbthreads/images/graemlins/devilgrin.gif
That's pretty dramatic failure. Sheesh. Actually, it's a wonder to me the things work ~at all~ for over ten minutes! Magic.
You can't use a sawzall for new ring grooves, the blade is not wide enough.
Use the angle grinder with a metal cut off wheel, it's the perfect size.
