Izual Angel
I know I've asked a lot of questions lately, but I'd rather get all this done correctly rather than botch it on my own.
1) Is there any way to un-seize a smog pump other than installing it with the belt really tight and revving the engine until it breaks loose?
2) The cylinder head bolts, nuts and studs: Can they be safely re-used? I only ask because I've got the intake manifold removed, and it would be really easy to remove the head and change the gasket (I have the gaskets already) and I don't really have $80 to spend on a new set. Any advice? (Don't tell me not to be cheap /ubbthreads/images/graemlins/crazy.gif )
3) And finally, that lifting eye that mounts on the front of the block... How is it oriented? Is the eye facing the rear side of the block, or the front? My tr7 didn't have one installed when I got it, but the box of junk in the trunk had one in there.
Thank for the help.
Thank for the help.
