Having got the engine finished and on a stand I have been trying to get it started.
It has a 25D distributer and I believe the wrong distributer cap. The TR3 cap and the MG cap look like there is a 90 degree difference in the plug wire location. I will be ordering a new cap from Moss. At the moment it has the TR3 cap and I made allowance for that when I connected the plug wires.
I have the distributer drive set with the slot at about 7 and 2 with the slot below the center line. With the engine set at TDC on No.1 cylinder on the compression stroke the rotor arm is pointing to the 7 o clock position. I thought it should point more to 3 o clock. Could the drive dog on the distributer be in the wrong position?
It has fired and almost run a couple of times.
David
David
