IanF
Howdy. /ubbthreads/images/graemlins/savewave.gif
Before we take Baldrick out for another drive, there are a couple of things we need to look at. Unfortunately, we may want to drive the car again before getting a shop manual or even the owner's manual, so please bare with me on a couple of questions:
1. How is the best way to jack up the car? I need to get the rear of the car on jack stand to inspect the u-joints and wheel bearings as well as check the diff-oil.
1a. As I think about it, I'm startng to think the rear-end noise is bearing related. The noise is the same regardless of engine power and from what I remember, the noises u-joints make tends to change depending on whether power is being applied or not. How difficult is replacing the rear wheel bearings?
2. While the engine starts quickly and runs great, it does idle a bit high. Aroung 2000 RPM. Might be a vacuum leak... or timing... or idle adjustment. What are the timing settings? How to adjust the idle speed? Any other tips?
That is all...
...for now... /ubbthreads/images/graemlins/smirk.gif
That is all...
