Hi Guest!
I just tell them these aren't the droids they're lookin' for.anthony7777 said:gregw, interesting and sexy but in my opinion very dangerous, youd never know who on any given sidewalk might carlesly whip out thier light saber as you drove by, a natural reaction i spozz. /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
Assuming that you are serious, a generator doesn't put out much voltage at low rpm such as idle. The battery is likely at about 12.5 volts & the generator is putting out about the same or less. As engine/generator speed is raised, the generator will put out more like 13.5 to 14 volts. Not only do the lights get brighter, but this is the only time that the battery actually gets charged.tahoe healey said:Any one know what happens with a generator where the brightness reduces when the engine idles?
GregW said:Hi Bobby,
As it is right now, I wouldnÂ’t use this on my gauges, I donÂ’t think itÂ’s bright enough. I might get a couple different colors of the high intensity wire from the site that Ooman found, just for fun. The inverter is enclosed in a small plastic housing that could be mounted anywhere safely. Way up under the dash, with the motor running, it most likely wouldnÂ’t be heard.
IÂ’ve been very impressed with the new LEDs coming recently. I bought a dozen of the LAPDs new tactical flashlights. Literally, you could read a book if the flashlight was forty feet away from you, it has one LED in it. The Luxeon LEDs I mentioned earlier have a very wide dispersion. I had spots on my retina immediately when I lit one up. Even 90Âş off axis.
The tach & speedo look so good with the LED that you'd be tempted to think the electrical system wasn't Lucas..AUSMHLY said:Well guys, I'm finally finished with this bright idea.
I started this project on 12.28.07.
Here it is 02.03.08
I tried a lot of different bulbs.
The 8 watt filament bulbs got to hot. Even the stock 2.2 watt bulbs give off some heat. Feel your fuel gauge.
Led's seem to be the answer. No heat, instant on, use a fraction of the power and most likely will out last the car.
I've learned there are a lot of new types of led's out now. I'll be attaching a photo that shows some of the ones I tested.
I replaced all the stock E10 filament bulbs with led's.
The led that worked the best was the one that reflected a light pattern of 180 degrees. The color made a difference too. The white/blue (cool white 8000k) lit up the gauges the best. The stock filament bulbs give off a soft yellow-ish (warm white) light.
Painting the insides of the speed and tach barrels gloss white also helped reflect the light to the front of the gauge. Nothing could be done about painting the inside of the fuel gauge because of the way the light reflects off of the two piece gauge front. I did not take the oil/water gauge apart. It appears to get light the same way as the fuel, via a straight shot down the light tube in the back.
Here is a believe it or not. The green directional arrows can be clearly seen....in daylight. Whodathuhk.
Same goes for the blue and red plastic gems in the bottom of the speed and tack. Clearly seen in daylight.
To balance out the reflected light (from the effort of the single bulb) in the top of the speed and tach, I added one more led to the back side, bottom of each gauge.
OK, enough blah blah blah. Show me the before - after /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
These were taken at night, in my unlit garage. No flash
