jlaird
Rear of the block at the crankshaft is a half circle peice held on with three bolts. It has a gasket as well, think it is called a rear cover but can not find a reference. Found a reference and that is correct, rear cover but breakdown shows lock washers, I am almost sure that safety wire goes here?
The bolts are drilled for safety wire, does anyone remember is this the spot that wire is required?
I seem to remember that only one place on the engine requires it, is this it?
