948 piston rings
59Bugeye
Does anyone know where I could find .010 over rings for stock 948 pistons. It seems everyone carries std and .020 but I haven't found .010.
Call ARP...they should have them.
Their website is awful, but it'll give you an idea of what they have and their contact info:
https://www.aptfast.com/
If APT doesn't work out for you, then you may try a company like Total Seal that works with bore sizes, now mind you, there's not alot of choices for a bore size that small. TS would nned to knoe how deep the ring lands are (radial depth) and tall they are (width).
""""""Does anyone know where I could find .010 over rings for stock 948 pistons""""""
what are U trying to do here......maybe file fit the rings and a standard set has too much gap?
your quest doesn't make sense.....either that or I dont understand what your doing??
Other sources might be Grant or Hastings, but you wont find a .010" set.
Dumb question here. Why 10 over rings on stock pistons? Have the thing boored and go with a set of pistons and rings. About 160 for the parts.
