948 convert to 1275 info
Find a 1275 engine and make the swap. When I did mine, I found engine and transmission. It should be pretty straight forward. I was warned that I needed to upgrade the brakes to Disk on the front. If you are going to go faster, be able to stop.
You will also need to convert to an electic fuel pump. Most electric pumps are "pushers", so it should be mounted close to the gas tank.
Have the 1275. Elec. pump is in place. Are there "fitting" issues? Does everything lash up the same? re: braking. I don't want to go faster, just a little quicker. Maybe there is little or no trade off here. Any more comments appreciated.
Smooth case trannys don't mate to 1275s. Other than that everything fits up. .. Oh, tach. No more generator drive tach. You'll need a later one.
Regarding Tach, just use the generator from the 948 engine. Same generator except for the tach drive back plate.
Get yourself a Haynes manual and keep your eye our for an original/reprint BE manual. Make sure that you're happy with the condition of your clutch before installation, as that would be very annoying to discover as a problem, after the fact. Also keep your eyes out for a disc brake set-up for the front (and pickup the corresponding rear drums as well; save some money for resleeving the master cylinder) as I don't think you can ever have too much braking power, and the twin-leading shoes on the BE aren't quite up to today's standards. I'ts been quite a few years since I was swapping out tired 948s in our car and then moving to a 1275, but I don't recollect any problems. Real clearance issues between the bottom front pulley and the frame with our Datsun 5 speed install (still not on the road). Next time that unit is out, we'll be cuting the (hopefully) appropriate sized hole in the top of the Datsun bell housing. Good fortune, and have fun. Doug
Actually a 1275 will bolt up to a smooth case transmission. It is a 1098 that won't, the pressure plate on the 1098 is too big.
Billm
Bill,
My '68 Sprite, Bugsy I, had a 1098 installed with a Smoothcase Tranny. Not sure what was done to make it work but I bought it that way, and I drove it for 12 years and then sold it to Alan Fisher in NH about 4 years ago, and I believe he is still driving Bugsy I. A '68 with a BE Bonnet.
Yes, you can clear the bell housing of a smooth case to accept a 1098 pressure plate but it isn't a direct fit. Not hard to do but not real quick either
Bill
Thanks Bill, hope all is well with you and yours. Take care.
It's good to hear you already have discs, the most important upgrade, IMO. Are they already on the car and do they function well?
As memory serves, it's much easier to use a complete 1275 (including HS2 carbs versus H1s on a stock bugeye) & ribcase transmission setup as the thin stamped backplate on the 948 doesn't fit the 1275 properly, though it can be modified to "sort of" fit with lots of work.
The ribcase is a stronger transmission and is much easier to source parts for, and to rebuild, than the early transmissions. Using the 1275 exhaust manifold (or a header) & later pipe as mentioned above really helps the 1275 breathe.
Scotsman Starter Motor brush spring 1948-54 Petrol and Series 1 and 2 2LT Diesel Rover / Land Rover 10
sim 948 aluminum head gasket Spridgets 2
R Extra 948 and 1098 Engines Spridgets 9
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
M 948 Engine Rebuild Question Spridgets 0
M Vacuum Line on a 948 Spridgets 4
B Dashboard color Austin A40 Devon 1948 Restoration & Tools 2
A Bugeye engine swap, 948 to 1275 Austin Healey 11
pbraun For Sale Free 948 and smooth case Spridgets Classified 0
M 948 Engine ID help Spridgets 3
apbos Turbo 948 engine? Spridgets 3
F Ribbed case tranny in 948 bugeye Spridgets 2
J New Guy 948 ribcase question Spridgets 6
M Timing Chain on 948 Rebuild Spridgets 1
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
M 948 Side Cover Needed Spridgets 0
M Need Advice On 948 Engine Rebuild Spridgets 7
M 948 Pulley Nut Size Spridgets 1
M Engine Stand - What Bolts Recommended for 948 Spridgets 3
Jim_Gruber Shift Points for Bugsys 948 w Cooper S Head Spridgets 3
M 1275 to 948 Generator Swap - Need Input Please Spridgets 4
Jim_Gruber Static Timing a 948 in a BE Spridgets 12
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
B Reinstalling 948 engine Spridgets 7
AN6-TX 948 Thermostat Housing Spridgets 11
certifiedcarnut 948 front brake shoes warning Spridgets 5
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
SD Bugeye Are there any of us with 948 builds left? Spridgets 13
M 948 clutch hydraulic line Spridgets 7
bugedd So I drove my first 948 Bugeye...... Spridgets 25
D wtb 948 exhaust manifold Spridgets 3
K 1948 Austin Sheerline engine and trans for sale in Winnipeg Manitoba Other British Cars 0
D 948 Oil Cap Spridgets 5
Trevor Jessie 948 engine with a 1275 head question. Spridgets 3
R 1948 Jaguar MkIV Landau Jaguar 4
D 948 clutch kit Spridgets 2
B 948 flywheels? Spridgets 8
6 Valve adjustment stock 948 Spridgets 11
longbridgehealey speedo cable 948 to 1275 Spridgets 2
I source for used 948 oil pan Spridgets 4
longbridgehealey another 1275 from 948 question Spridgets 3
longbridgehealey generator from 948 Bugeye Spridgets 2
B MG Motor - 948 parts or 1275 engine MG 1
7 948 sprite chewed the number three rod bearing MG 10
L Ribcase transmission with 948 engine Spridgets 8
I Bugey 948 engine rebuild gone wrong - need help Spridgets 12
M Differences in Slave Cylinders for 948/1098 & 1275 Spridgets 5
I Bugeye 948 ignition timing help please Spridgets 8
I bugeye 948 rebuilt engine - no oil pressure, Spridgets 7
