'90 XJS waist molding question
VLStu
Hi there!
Ive been working on a '90 XJS for the last year, and am getting ready to take the plunge on a paint job. One item I have to replace prior to the new paint is the weather seal molding that attaches to the top of the doors, and wipes the window as it goes up/down.
Has anyone had experience with this, that can give me an idea if it is a "do it yourself" type job?
Thanks!
Sometimes that rubber will slide out if it has not been glued, then you can drill out the rivets after you remove the glass.
Thanks again - that seems to have been the trick. IT just crumbled on the way out, but it helps to know how to install the new material.
Stu
