Michael J.
I did a complete rebuild on a 90 Xjs V-12 with Marelli Ignition. When installing the timing chain, I positioned the crank so that timing mark was cylinder 1-A TDC. Used a Cam Guage. Engine turns over freely, but won't start. Ignition fires correctly with inductive timing light, but the engine seems to fire during exhaust stroke. I used new Bosch Platinum plugs with the called for .025 gap.
If valve timing was off, would engine have bound up when turning over with a wrench during the build?
I have looked for air leaks, found none.
I am fresh out of ideas. Any thoughts anyone?
Hi Guest!
