Michael J.
Hello all!:
I swapped the fuel pump and master relays with another set.
problem is still there.
The sound that I hear with the stethyscope is from touching the fuel pump below the battery. It is not running at high speed or at least it sounds slower than when the engine is running.
The sound is there if I pull the relays.
I presume that the relay with the red diagonal strioe goes in the red connector and the other in the black. Correct?
The relays are different part numbers and the wiring diagram says one has a diode inside.
It appears that this is a short of some type.
More to come.
Pr
More to come.
Pr
