glemon said:My brother stuck a radiator from an older Volvo on his TR3, it had to be angled a bit to fit, I beleive he can now pull the radiator without pulling the shroud, he say it helps cooling greatly, not a great cost but some fettling and sourcing of parts to get it done.
Indeed, that is true. Had exactly that problem with my 59 TR3A : the tubes were no longer in good thermal contact with the fins so even though the radiator flowed fine and held pressure (as tested by a radiator shop), it's thermal efficiency was lousy. A new core made all my overheating problems disappear.swift6 said:Just because a radiator is boiled out and tested doesn't mean that it will operate at peak efficiency.
A non-sequitor ... the inside of the cylinders is normally much hotter than the water jacket, so better heat conduction between the two WILL increase the heat transmitted to the coolant and hence overheating (since coolant overheating is what we measure/care about).trfourtune said:thin liners will transfer heat faster than thicker ones so overheating is not caused by this.
TR3driver said:A non-sequitor ... the inside of the cylinders is normally much hotter than the water jacket, so better heat conduction between the two WILL increase the heat transmitted to the coolant and hence overheating (since coolant overheating is what we measure/care about).trfourtune said:thin liners will transfer heat faster than thicker ones so overheating is not caused by this.
Our engines operate mostly on thermal expansion ... if the combustion chamber was held at coolant temperature (perfect heat conduction) they wouldn't run at all.
