88 xjs injectors
wilde_knight
i figured out my ignition problem, but i have an injector problem now, i'm not getting any power to them, any one have any suggestions? thanx
The injectors are actuated by the fuel injection ECU that is pulsed by the ignition amplifier signal. Either you have pulled a wire loose from the ignition amplifier curcuitry, you have an ECU problem or a fault in the injector actuation circuitry like the ballast resistors. Hope this helps.
