internal or external?? If you are going to pull the head and fix it properly, I have a suggestion for you. Make a flat fairly thick steel plate that will fit between the cam covers. Drill and tap holes at each head stud location. Obtain long bolts for these. Drill holes above each spark plug hole. Cut off some scrap plugs, and well some all thread to those.Screw the plugs into the plug holes, and secure the plate with nuts and washers as required. When you are absolutely positive all attaching bolts are off, thread the long bolt thru, and have them push on the head studs. Screw the long bolts evenly and the head will rise up like you planned it that way.This sounds like a lot of work, but it is NOTHING like trying to get a stuck head off of a 4.2. Also, the intake manifold is extremely difficult to get loose from the head. The easy way is to just bring it off with the head, and deal with it on the floor. Good luck!!.
