My RH headlamp is dim. Tested with new headlamp with same result...dim. High beams cause RH headlamp to basically go off.
Any ideas on how to fix this?
Do the headlamps have one relay running both or one for each side? If there is one for each side, swap them and see if the problem moves. Might just be a relay issue.....
Thanks for the "ground connection" advice. I indeed located the connector and found that the ground pin was pushed out so there was little to no connection. I pulled it back into position with needle nose pliers and I know have full illunination!!
Thanks again.
Tim
Had a similar situation last week... when switching from low to high beams all my headlights went out. I pulled over and switched back to low beam and they came back on.
I traced it to a bad ground. All is good now!
