Having starting problems!
Last week the car wouldn't turn over just clicking noises. Tried a new part on the starter and ignition relays and it seemed to be the ignition relay as it started when I replaced it with new.
Next day started on second attempt after first just had the clicking again. Gave the car a really good run and all was fine.
Last night came to start her up and just the clicking mainly with at one point the engine turning over slowly but did not fire up. After that it wouldn't start over again
Re checked all wiring again but must admit as a newcomer couldn't work out how to take the three wires off the started motor to clean and check it.
Beginning to wonder if it is some problem with the starter motor or the solenoid which I presume powers it?
Battery is new and have also replaced the ignition coil this week in my attempts to solve the problems.
Hoping someone might have some ideas??
Hi Guest!
