gregsdrums
It had been sitting in a dirt floor barn for 5 yrs. so I knew I had my work cut out. After many hrs. I'm finally at the point of starting it. Runs like a swiss clock, only problem - no clutch. Rebuilt master and slave, new line, bled the line, pedal was not great but could get in gear with some force.Feels like the rod on the slave needs to be longer. Even with engine shut off, car in gear, clutch engaged, you can't push it. Is it possible it has the wrong clutch? Would appreciate any suggestions...
