A friend of mine has a 78 spitfire 1500 that he has been restoring for awhile.
Recently it has started to die after it gets warm, it can happen idling in the driveway or out on the road. Yes it`s been on every sort of wrecker there is lol.
After it quits and we try to restart it acts like the timing is off, it will crank but wont fire til you let go of the key. Have check the diff, reset timing, he`s running a crane electronic ing. Replaced the coil, checked fuel,even pulled the inline regulator to make sure.
This has us stumped, it will not start again til it cools completely, as in over night.
He is running a header and a webber edg carb, I checked to see if it was vapor lock but can`t really tell. I pulled the plugs the last time it died, but they looked ok, not wet but not dry either.
Any help would be appreciated. Thanks
