Paul Slice
Hello all,
I know this horse has been beat to death but I have not seen this question on the topic.My 78 MGB has had the emissions removed,Weber DGV carb with Pico header and exhaust. I installed a Piper fast road camshaft along with new rings and rod bearings to the 80000 mile motor along with a new WP and oil pump also oil pressure regulator(stock volume).The dist. was replaced with a eurospec one from Bob at Brit-tec.I used hydromar sealent on all the gaskets and packed grease into the inner rings of front and rear seals. The crankcase pressure is vented to the Webers air breather but I also tried the ventura hanging hose trick. The motor still seeps oil around most gaskets as well as a slight drip around the rear main seal area. I also have a 80 Spitfire that has received the same treatment and does not leak or seep any oil.The trick on the Spit is to vent from the fuel pump blocking plate as well as the valve cover. This involves venting the pressure thru a small hole in the plate up thru a 1/2 inch hose to a hanging K&N filter mounted on the back of the valve cover. Will this also work on my MGB which has a blanking plate also, instead of installing PCV valve in the intake?
thanks Paul
thanks Paul
