Svcmangler
I am unable to shift into reverse when the car is running. It just grinds. If I turn the car off, I can then shift into reverse. I have just replaced the clutch, throwout bearing, pilot shaft bushing as well as the clutch master, clutch slave, and clutch hose. The hydraulics have been bled, so no air in the lines. All other gears shift perfectly. thoughts as to what can be causing this?
