Flatlander
I have a 77 Spitfire. Prior to buying I believe the previous owner installed a new horn/headlight bright light stalk that fits on the left side of the steering column. (Found the box for the new part in the trunk.) However something is wrong. In the "normal" setting (bright lights not activated.) the stalk is only about 1/2 inch from the rear of the steering wheel and interfers with operation of the steering wheel. It appears that stalk needs to be bent back or the steering wheel needs to flow away (bend) away from the stalk such that there is more room. My initial thought was that the previous owner had replaced the steering wheel with an earlier one but the mounting point on the steering column looks to be consistent with the wheel. The steering wheel is held to the column by a large bolt and the wheel is registered to the column by a square insert rather than the splined connection I am used to seeing. Do the 77 steering wheels match the 78-80 wheels? (Can't find any references to check.)
Has anyone else come across this problem?
Thanks,
Gary
Thanks,
Gary
Hi Guest!
