kyreb1862
I'm having a problem getting my 77 B to rev above 4000 rpm. At 4000 rpm the car just seems to bog and at the same time the tach needle starts to jump. Below 4000 rpm, no problems at all. The car is currently running a ZS carb with a K&N air filter on a Jet Hot coated Austin Marina intake/exhaust. The exhaust side of the manifold feeds into a custom 2 inch exhaust system. I modified the carb by removing the poppet valve throttle disc and installing a solid throttle disc. The car is equipped with the factory CEI ignition and is currently timed at 12 degrees at 1500 rpm, the plug wires check out good and the plugs are Champion R9NY's. The plugs are gapped at .035 they show a dark brown to black color with the front two plugs being a bit lighter than the back two plugs. Any ideas or suggestions would be appreciated.
Regards John
Regards John
Hi Guest!
