kyreb1862
First a little back ground. The car is a 77 MGB, mostly stock, fitted with the Lucas 45 DM 4 distributor, the CEI system. I have owned this car for six years. I am currently in the process of converting to SU HIF 4 carbs. While in the process of balancing the Su's today the car wanted to run a bit rough and pop back trough the carbs. I checked the timing and found it much to advanced so I set it on 10 degrees BTDC and all was good. Then suddenly the car just stopped. I tried the starter and it cranked well but no start. I walked around to the ditributor side of the car to check electrical connections when I suddenly realized that the distributor had turned until the vacuum adavnce unit was against the starter. I thought the distributor may have gotten loose and turned but I quickly found out that I could not turn it by hand. I took a hammer and block of wood and finally got the distributor tapped around to a position that I knew the car would start in. I went back to the passenger compartment and hit the key, still nothing. I went back to check the distributor and it had done the same thing again. Could someone please tell me what is causing this? I haven't had a chance to pull the distributor yet and probably won't before this weekend. Any help would be sincerely appreciated.
