A few days ago, I received my rebuilt 25D distributor from Advanced Distributors. Quite the showpiece; only bad thing is, it makes the rest of my engine bay look bad
. The car in question is a 1977 MGB, 25D distributor with points, twin SU HS4s.
Anyhoo, I confirmed points gap of .015 and installed the distributor. I turned the engine over to have number 1 at 10 degrees before TDC. Luckily, the rotor pointed to 2 o clock where it usually does for number 1, so I didn't have to fiddle with repositioning. I went to static time the engine with my test light; lo and behold, my test light would only light up intermittently on the LT post. It started out OK when I first plugged the light up; when I started to turn the distributor clockwise, the light went out as it should. However, when I turned back the opposite way, the light didn't come back on at all. I rocked the rotor a bit and it came back, but started blinking and finally went back out again. As such, I wasn't really able to get a good time on the engine with the light.
I did a visual timing by watching the points open and close as I turned the distributor, stopping it at the point where the points just start to open and locking it down at that point. I know it isn't nearly as good as what a test light or timing light would give, but I thought of it as acting on the same principle as what the test light shows.
Not surprisingly, the engine would not start. Oddly enough, when I first tried to start the engine, I heard something snap and crackle from under the hood after one crank, and the ignition light died out. I disconnected the battery and took a look under hood to find nothing appearing amiss. No smoke or loose wires. I reconnected the battery and tried again; it cranked and cranked, but no start. I recently had to replace the fuel pump and I can confirm fuel flow to the carbs.
I watched the John Twist video on static timing and did as he did, connecting the test light between the LT connection on the distributor (lead disconnected) and fuse #1 on the fuse box; I've read also that it can be done by connecting the test light to the white/black at the coil and ground. Should I have done it this way instead?
Help?
. The car in question is a 1977 MGB, 25D distributor with points, twin SU HS4s.Anyhoo, I confirmed points gap of .015 and installed the distributor. I turned the engine over to have number 1 at 10 degrees before TDC. Luckily, the rotor pointed to 2 o clock where it usually does for number 1, so I didn't have to fiddle with repositioning. I went to static time the engine with my test light; lo and behold, my test light would only light up intermittently on the LT post. It started out OK when I first plugged the light up; when I started to turn the distributor clockwise, the light went out as it should. However, when I turned back the opposite way, the light didn't come back on at all. I rocked the rotor a bit and it came back, but started blinking and finally went back out again. As such, I wasn't really able to get a good time on the engine with the light.
Help?
