Just had the clutch replaced for the first time on my 26,000 mile 76 TR6 last fall before putting away for the winter. I used a B&B kit from Moss and also replaced the cross shaft,bushings, fork, hardened pin and T/O bearing sleeve. Got it on the road last week and the clutch seems to perform just fine in leisurly driving. However, under hard acceleration there is a slight lag before clutch re-engages after every shift - rpm runs up for a second and then it catches. Does this sound like the binding T/O bearing sleeve that I've read about? Why would it happen with a new sleeve? Any chance it will improve as new parts break-in ? Any chance it's a slave cylinder problem? Your thoughts/ experiences will be much appreciated.
Hi Guest!
