MichaelJones
Just moved from New Hampshire to Virginia and when my 76 Midget arrived it would not start. No power from the coil to the electric fuel pump...I tested the fuel pump directly to the battery and it workd...so the problem is somewhere between the battery and the coil.
Wiring on the car is not great and should probably be replaced, but I don't have the time or the expertise to tackle the job...I've always been able to track down wiring problems as they occur and take care of them, but this one has me vexed.
I do not know much about the electrical aspects of the car and thus far have cleaned all connections and made sure all of the wires are sound. Is this a bad coil or is it between the battery and the coil...the solenoid?
The car is not a show car, just fun for me and my children on the weekends. Any help would be greatly appreciated.
Mike
Mike
Hi Guest!
Use the fuse box fuse; there is an extra blade on the one that's switched. That's what I did when I put the electric pump in. Coming directly from the coil you have the ballast resistor which is dropping the voltage; not good.
