Too true, Roger. Good link.
That's a Luminition Hall Effect dizzy, a Lucas 45D. Best to replace its guts with a Pertronix unit.
As I posted in the earlier response, the Luminition system was first fitted in the '76 cars, to the best of my recollection. The control boxes were problematic. Even if the original Lucas parts were obtainable, a better solution is the newer, more robust Pertronix kit. and someone who understands how to fit the pieces and time the ignition after the change. Moss sells the conversion for just over $100, then someone with familiarity should be able to install it and get it going for at MOST two hours' time. It should take less, though. There's a client's '77 here now which I swapped out in less than 30 minutes.
