EWD
Afternoon folks! Couple of questions please
In the process of installing a rebuilt trans with OD. (Have not rec it yet). The original trans was a 4 speed.
Does it bolt to the rear mount the same? (I have removed the brackets and replaced the rubber mounts.)
It comes with a new escutcheon. Best way to run the wire to the switch? Really a tight fit with the existing harness. Can the wire be run in another channel installed alongside the channel beneath the steering column?
Any other guidance on the install?
Thx,
Will
Thx,
Will
