EWD
Just received my rebuilt J type OD trans (converting from standard 4 speed). Noticed that it does not have a support arm that bolted on the right side of the shifter. The old support arm attached through the rear support bracket. Even if there was a bracket, with the different mounting of the trans to the bracket, there is no place to secure an arm unless a hole was drilled.
My question: Is there a support arm? I don't see it in the parts diagram. Is one needed?
Thx,
Will
Thx,
Will
Hi Guest!
