ScottTR6
Started my Triumph up for the first time in about a year, having finished some interior work finally. No problem starting or running, but after shutting down there was fuel streaming out the bottom of the Carb. Everything is original, never had a leaking fuel problem before. Has something stuck from an extended shut down, or do I need a rebuild? Thanks, Andrew
