TR6 '74 - J Drive Transmission install
EWD
Still trying to install my new (rebuilt) J Drive transmission. Have a new brass bushing sleeve (Moss) and Koyo throw out bearing (Goodparts). The bushing fit smoothly over the shaft but after the bearing was pressed on, it appears to have compressed and is too tight. The bearing pressed on smoothly with no problem. It will not smoothly rotate and will not travel th length of the shaft. This is the second try with both the original and new bearing. Same situation. Moss also has a metal bushing (original specs) at 1/2 the price of the brass one. Anyone heard of this problem?
Thx,
Will
You're asking about the bearing carrier or the pilot shaft bushing ?
Morning Ken - I'm speaking of the throw out bearing carrier. I sanded it progressively with 100,150, and 600 wet sandpaper. With a little grease on the shaft and carrier, it willl now slide and rotate the length of the shaft, but it's still too tight. Hopefully I'm headed in the right direction. More coffee and a couple of Advil......
