74 B starts stops then difficult to start again
ron wilson
74 B Starts fine but after running for 10 miinutes when I stop at stop lite it dies and will not start again for about 10 minutes. It turns over fine but will not fire
zahnej
When it stops, squirt some ether in the air cleaner. If it starts, if only for a few seconds, you probably have fuel delivery problems, if not it's probably electrical. I'm not familiar with that car but if it has pollution control stuff on it - air pumps - egr - etc. I would look at that too.
PAUL161
Ron, Even though I don't think 10 min. is enough time to create a vapor lock, I would make sure that your fuel line is well clear of any heat source. Sounds like a typical vapor lock problem, but as we all know, Lucas has a way of throwing it's two cents in on occasion. Hot coil, weak condenser (for starting problem). Even a heat sensitive electrical connection.
Platinum
FWIW, I'd say check that the two low volt leads at the coil are clean and make good contact, and perhaps check the fuel pump flow in the driveway: Time a 1-pint flow before starting the engine, then again after a ten or fifteen minute "warm up" of the engine. Should both take the same amount of time... about a minute.
PAUL161
Re: 74 B starts stops then difficult to start agai
Not to dispute your post, but squirting starting fluid of any type in a hot engine is not advisable. As starting fluid has a very low ignition point, it will pre ignite in a hot engine and even though it's rare, it can cause piston failure and even bend a connecting rod.
Platinum
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif I would NEVER suggest using ether based "starting fluid" for anything. Especially anything you want to keep.
...mebbe for cleaning lawnmower parts.
zahnej
Paul, you are right on the hot engine!! I've used ether for over 40 years to diagnose engine problems but I've probably been lucky on the hot ones. In addition to the bad things that can happen in your post I always worry about blowing a head gasket hot or cold - sure will make an engine start though - especially in my former home in Wisconsin.
tony barnhill
Great Pumpkin - R.I.P
Does the distributor still have a condenser? If so, change it & see what happens.
tony barnhill
DING!!
vping
Bronze
/bcforum/images/%%GRAEMLIN_URL%%/winner1.gif
jlaird
Tony wins the prise, oh wait what prise.
P Jag XJ8 starts but then dies right away. Jaguar 4
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
John-Glen TR6 TR6 Only starts when being jumped Triumph 10
D TR2/3/3A Excessive cranking before it starts. Triumph 47
2billydavies TR2/3/3A runs excellent but starts hard after use Triumph 8
D TR2/3/3A engine :"stuck" even before it starts! Triumph 28
F TR2/3/3A Starts Cold, Not Hot Triumph 12
Jim_Gruber Bugsy II - Listing on e-Bay starts at 9:00 PM EDT Today Spridgets 1
H Spitfire Triumph starts just fine but Ignition is 'Off' and key is in my wife's purse. Triumph 6
aeronca65t Pittsburgh Vintage Grand Prix-starts on July 11 [and covers two weekends] Racing 0
Jim_Gruber And so Bugsy II Restoration starts/Shell Number/ RS Bulkhead/Evaporust works Spridgets 1
T And she finally starts to look like.. Spridgets 0
aeronca65t Retromobile starts today! Other Cars 3
middie Middie starts to strip down Spridgets 19
Brosky British Legends Weekend - starts tonight Triumph 8
J BN7 Starts after 25 years [but with problems] Austin Healey 31
doughairfield Engine rebuild starts today. Triumph 10
theleisure Wouldn't Start, Now Starts but Revs to 6000+ Spridgets 53
Westfield_XI MegaJolted 1380 starts and runs Spridgets 6
livinginthepast Runs good...starts missing...and then.. Spridgets 10
racingenglishcars It starts ! Rover / Land Rover 8
zimmy quicker cold starts Spridgets 5
kodanja Cold starts? Triumph 24
T She starts and restarts Triumph 1
danielnorton Starts but won't stay running? Spridgets 12
2wrench New Rotor, Car starts, but..... Triumph 6
go_inbroke cold starts? Triumph 6
356roadster 100M starts to drink oil.................. Austin Healey 34
P Midget 1500 starts when cold; doesn't when warm Spridgets 9
dklawson Spitfire Spitfire Dry Engine Starts-Need Smoke Explanation Triumph 3
wangdango '82 XJ6 starts, then sometimes does not.. Jaguar 2
AUSMHLY Barret-Jackson starts today Austin Healey 2
B It Starts! But doesnt run... Spridgets 9
S Car starts; carbs spew fuel Spridgets 4
philman it starts out a small job Triumph 9
B It starts...now it won't stop! Triumph 14
Bruce_B 1275 Engine Rebuild - It starts this weekend! Spridgets 19
bluemiata90 Starts without choke when cold Triumph 2
Mark_Gibson TR-2 Engine Out, Now the Fun Starts! Triumph 0
kindofblue It Starts, and Runs, and Runs on!!! Triumph 4
jaybird Hallelujah she starts! MG 2
S Wedge TR7 now starts [hard] and will not continue to run Triumph 11
M TR6 TR6 starts, runs, then dies Triumph 5
S MGB MGB, starts... not MG 6
D Overdrive Stops Working After Oil Change Austin Healey 26
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
Tr3aguy TR2/3/3A Welding in Frank’s bump stops Triumph 0
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
