73 Midget Plug and Points Gap
Hijaws
Hello!!!
Can anyone please give me the recommended plug and points gap for 1973 MG Midget.
Spring is here and would like to get it running, but not able to without this information.
G
Sorry, I have a "B" but it can't be too awful far off from that. .015 to .018 on the points and .028 on the plugs.
One of the spridget guys might get you closer.
aeronca65t
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by mrbassman:
Sorry, I have a "B" but it can't be too awful far off from that. .015 to .018 on the points and .028 on the plugs....
<hr></blockquote>
Yep...that'll work fine.
piman
Hello Hijaws,
really the points should be 0.015", as accurately as you can measure them. Plugs at 0.025" but they have slightly more leeway. By the way that is what an MGB should be set to also.
Alec
G
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by piman:
Hello Hijaws,
Alec
<hr></blockquote>
Well its been awhile. I have an infra-red pick-up on my ignition now. I thought I used to adjust the points to around .017 to allow room for some wear. Anyway, it used to work fine there.
piman
Hello Mr. B,
you have a point there, but did you put a smear of grease on the cam so as to lubricate the heel of the points?. Personally I gap using a dwell meter and no longer use feeler gauges, but my point is that a small variation alters the spark intensity and the timing, so should be as close to specification as posible.
In practice, some engines are more tolerant than others, usually depending on how highly tuned they are.
Alec
G
Hello Mr. B,
Alec
<hr></blockquote>
Yes, I used the grease and did back up my setting with a dwell check and corrected if necessary.
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
RickB YUCK!! Is there a floor drain plug 78 Midget? Spridgets 5
dingleberry3343 74 midget 1275 oil galley plug Spridgets 6
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
M MG Midget decoding Spridgets 1
JPSmit 60 years - Mg Midget Spridgets 0
M 1972 Midget Seat Belt Replacement Spridgets 4
D MG Midget in distress. Spridgets 155
D Is it a 1965 or a 1966 MG Midget? Spridgets 2
