72 XJ- 6 Fuel Tank removal
BruceAllcorn
Does anyone have a good set of instructions for removing the fuel tank from a 1972 XJ-6? I have the "quarter panel" removed, the gas drained and the sending unit disconnected. However, I am having trouble removing the filler assembly (gas cap) and I'm not sure where all the other attachments are that hold the tank in place. Any help would be appreciated.
LarryK
Bumper must go too, bolts from inside boot, remove fuel lines,push tank up, remove clamp on filler, remove tank. They have a Haynes manual at Autozone for $21.00.
drooartz Fuel tank screen removal Spridgets 17
H Fuel tank screws removal question MG 4
Moose33 fuel tank removal MG 5
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
BoyRacer Fuel Tank Sending Unit Austin Healey 3
B TR6 Fuel tank replacement Triumph 0
JPSmit Fuel tank sender - how does it work? Spridgets 4
S Large capacity fuel tank Spridgets 1
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
Ljohns New Midget/Sprite Fuel Tank Austin Healey Classifieds 1
Michael Oritt Fuel tank safety Austin Healey 18
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
R Jensen-Healey Fuel Tank Questions Other British Cars 17
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
wkilleffer MGB Classic Gold fuel tank drain plug MG 12
SD Bugeye Half capacity of the fuel tank Spridgets 10
B TR2/3/3A Fuel Tank Venting Triumph 8
Zimmycobra For Sale Original 1966 TR4A Fuel Tank Triumph Classifieds 0
L T-Series TD Fuel Tank MG 2
NutmegCT Fuel tank cleaning/restoration Restoration & Tools 47
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
sim fuel tank sender reading full all the time Spridgets 9
Basil E-Type fuel tank mounting bolts [$&^##$%*!!] Jaguar 16
J Bugye Fuel Tank Leak Austin Healey 4
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
T Wanted Jaguar MK2 fuel tank and Radiator Jaguar Classifieds 8
T TR4/4A Fuel tank venting Triumph 1
L 100/6 BN4 Fuel Tank feed Austin Healey 5
Popeye Engine starving for fuel before tank is empty - 2001 Audi TT Other Cars 5
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
R Fuel tank straps Austin Healey 15
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
L Fuel Tank sender 100/6 Austin Healey 8
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
K TR4/4A Fuel tank options Triumph 4
O TR2/3/3A Fuel tank vent Triumph 1
Csarneson BN4 Longbridge Fuel Tank Austin Healey 15
E TR4/4A TR$ Fuel line from tank Triumph 13
rjc157 Fuel tank sender Austin Healey 13
S Hot tip: seal for fuel tank sender Austin Healey 9
B Fuel tank woes Austin Healey 4
catfood BN1 Fuel tank straps Austin Healey 5
TulsaFred Fuel Tank fitting and nipple Spridgets 6
