TR6 72 TR6 Speedo cable
porgytirebiter
Speedo is not registering now. Have owned this one for 37 years and this just started recently. Have changed the cable, bounced for a little bit then died. How easy is it to change out the Speedo gear! Thanks,
Porgytirebiter
Madflyer
If you are talking about the right angle at the trans. not bad from under the car. It may be your problem there is a small piece that goes into the trans at the right angle that can brake. If you just slid a new cable in the old case and did not find anything wrong with the cable that angle would be likely the problem. If it is the gear assy in the trans it is all in the right angle assy and a new one is needed. Madflyer
P
porgytirebiter
Madflyer, thanks for your reply! My cable goes straight into the tranny through a single collar, not a right angle. I have looked up and seen the gear, but was looking for input to the ease or difficulty of installing it? I will most likely purchase the gear and housing and take on the task of attempting the install.
thanks again!
2wrench TR6 '74 TR6 Broken speedo cable Triumph 1
S TR6 TR6 speedo to electronic conversion anyone? Triumph 15
hondo402000 TR6 Rebuilding TR6 Speedo Triumph 4
glemon TR6 TR250/early TR6 v. late TR6 Different Speedo Ratio Triumph 4
K TR6 Speedo gear housings :TR3 and TR6 Triumph 3
TR674 TR6 TR6 Speedo guage Triumph 5
Airfix TR6 TR6 overdrive speedo pinion Triumph 2
kodanja TR6 71' TR6 Speedo anyone? Triumph 8
ScottTR6 TR6 74 TR6 Speedo & Tach Triumph 10
C TR6 TR6 speedo and bushing grease ? Triumph 3
S TR6 Speedo problems [TR6] Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 1
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engineā€¦ Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
EWD For Sale ā€˜74 TR6 original wheel trim rings Triumph Classifieds 3
