TR6 72 TR6 dash lite reostat question
roofman
To eliminate the reostat, can you just connect the wires behind it? I think I have a short and never use it anyway.
MDCanaday
In the last year,I have done a 71 a 73 and a 76,,,,,call british wiring and buy the book on tr6's best 30$ you ever spent.
MD(mad dog)
G
There are two switches that make no sense in the TR6. The dash light rheostat and the interior on/off light switch. The latter in my case is now an electric fan bypass switch (just have to get the proper knob, they actually make one with a fan logo) and the rheostat will someday be something useful. Makes no sense to dim lights that are already too dim to see. My 73 has a seat belt warning light on the dash (yeah, right, that is still there) that is now an on/off lighted rocker switch for my fog lights relay. Found a switch made in the UK that fits the hole perfectly. Too cool.
Paul Johnson
Yes, you can bypass. You likely don't have a short though (or the car would have gone up in smoke) but an open. The switch is very easy to clean and repair. There are several little tabs on the back that can be bent up which allows the switch to come apart. You then need only to take out the wire coil and clean it. Clean also the wiper tang on the rotating part. Put it back together and enjoy.
Agreed, the piece is of little use, but it is satisfying to repair it rather than just replace or throw out.
71tr
I noticed one of the smaller UK based vendors offering a push-button starter switch to replace the rheostat. Looked very cool, but can't remember the vendor.....somewhere in my notes.
roofman
roofman
Out of curiousity, how would this set up work w/ key and ignition? How would it be wired in?
I've seen these set ups for Honda S2000 models for sale on ebay UK for 20-30 dollars complete w/ relays.
roofman
roofman
go to ebay ( don't go to UK site) and type in
honda start button, and there are a number of listings fron US and UK sites.
It says you turn the key 2 clicks then hit the start button, or you can still use the key. $30-40 bucks for the whole kit. Very cool.
DNK
Dang Roofman, Answering your own questions. That's a sign of genius!
Here's my plan for the rheostat area.
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
EWD TR6 TR6 top dash trim paint Triumph 2
I TR6 Thickness of original TR6 dash Triumph 2
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
rjc157 For Sale 74 tr6 dash Triumph Classifieds 2
S TR6 TR6 Dash refinish: a nice surprise Triumph 4
S TR6 Removing TR6 dash [and suggestions on refinish] Triumph 12
TR4nut TR6 TR6 under dash pics? Anybody? Triumph 9
J TR6 TR6 Dash knobs Triumph 2
JimTR4 TR6 TR6 dash support in a TR4? Triumph 23
G TR6 TR6 dash and windshield frame removal Triumph 13
Coyote1 TR6 TR6 Dash Support won't go in Triumph 9
Tr4dude TR6 Tr6 resto dash Latest Triumph 3
V TR6 TR6 Center Dash Support Triumph 16
C TR6 TR6 Dash replacement, now only the horn works Triumph 6
S TR6 TR6 Dash Triumph 18
G TR6 Dash support options for TR6 Triumph 8
Brosky TR6 Free dash panel, late TR6 Triumph 4
G TR6 TR6 original dash bulbs as bright as newer bulbs Triumph 1
G TR6 TR6 dash lights not bright enough Triumph 22
mrv8q TR6 In the dash, '74 TR6 Triumph 2
I TR6 Veneer sanding, TR6 dash Triumph 3
C TR6 TR6 Dash Support Triumph 5
M TR6 TR6 dash Triumph 13
hondo402000 TR6 Veneering a TR6 dash Triumph 15
hondo402000 TR6 need a used dash for 71 TR6 Triumph 1
2wrench TR6 Pictures of TR6 dash refinished front + back Triumph 22
I TR6 TR6 dash help Triumph 8
I TR6 TR6 Dash help Triumph 7
I TR6 Reveneering TR6 Dash Triumph 3
T TR6 "Might as well" if you need to pull the TR6 dash Triumph 6
B TR6 Installing a new dash in TR6 Triumph 38
2wrench TR6 How do I remove the rheostat from dash of TR6? Triumph 23
2wrench TR6 Need replacement bulbs ID'd for under dash '74 TR6 Triumph 4
F TR6 Looking for TR6 metal dash support Triumph 4
R6MGS TR6 TR6 Under Dash panel?? and dash cap Triumph 10
I TR6 TR6 dash refinishing Triumph 7
J TR6 TR6 DASH HELP? Triumph 6
G TR6 tr6 - really dumb dash question Triumph 4
nathandarby67 TR6 TR6 Dash on ebay Triumph 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
