dklawson
'72 Spitfire Oil Pressure Update
I started a thread last Saturday about our project Spitfire's maiden voyage. It did not go as well as I'd hoped. Oil pressure was one issue, the gearbox was another.
This week I checked the calibration of a Smiths oil pressure gauge I will be installing in the dash. Today my son and I installed the gauge and took the car around the block to determine a baseline oil pressure. It was about 15 PSI with a hot idle (180oF water temp, 800-900 RPM).
Then we changed the oil to fresh 20W50 and took another lap around the block (after letting the car idle for a while). The oil pressure was only slightly better... perhaps around 20 PSI (with wishful thinking).
This car is not a restoration project. It is to be a moderately reliable daily driver for around town, not for long highway trips. As such, I'm not thrilled about pulling the engine and/or doing a complete rebuild. I can see dropping the pan and putting in new bearings and a new oil pump (assuming the crank isn't toast).
As a stopgap measure during our work, I may (God forbid) simply add STP or similar to the sump to bring up the viscosity. Apart from the bearings and oil pump are there other short term things I can do that don't involve pulling the engine?
BTW, for those who read the previous thread and want more info on the gearbox, I'm convinced it's the synchros on 1st and 2nd. Careful shifts with the pedal all the way down still ground. Double-clutching completely eliminated the problem. If my friend Jamie does have a later 1500 gearbox, that will be our fix. While the box is out we will have our opportunity to work on the oil pump and other bottom end oil related issues.
