I have a '72 Midget that has been in the family since new. I parked it 2 years ago after it developed some running issues which I think were just points / rotor. I want to get it running again and install an electronic ignition, then chase the running issues if they still exist.
I've drained and replaced the gas, oiled the cylinders, oiled the valve train, removed the spark plugs and turned the motor over by moving in 4th gear. With the spark plugs out it turns over freely. With the spark plugs in I can't get to turn over. The starter isn't strong enough to turn it and moving the car in 4th gear will only get one revolution before the tires lock up.
Any suggestions you guys have would be greatly appreciated.
Thanks.
Thanks.
