RickB
All right, I have just spent some "quality" time with the B.
Before I started it would start, run roughly, spit & cough & backfire.
After a bit of work it wouldn't start at all.
After a bit more work I got it back to how it was when I started. :frown:
Here is what I know:
The points were set a bit tight, I adjusted them to .014
When it "idles" it backfires and spits a bit of fuel spray out the carbs.
When I can get it to run up at 4000 - 4500 rpm it runs a little rough but not as bad as at 'idle'.
When I turn the key on and manually open the points I can't see a spark.
If I open up the points by turning the engine a bit then cross between both sides of the points with a screwdriver I do get a spark.
Meter from plate to ground = 0 ohms
Meter from points to coil = 7 ohms (what should it read?) That's to the wire that connects to the side of the distributor via the spade lug.
Meter from one side of points to other when closed = 0 ohms
