19_again
The tranny was rebuilt by DPO, but then parked after a year or two then sat for 20 years. My local shop has it and suggests that aside from the obvious seals etc. I replace the lay gear . The reasoning is very small rust spots on some teeth, I mean "get your glasses" small, that are the result of sitting with these teeth out of the fluid and condensation working on them. I'm told this will attack the hardness and manifest itself in a noisy tranny at best and broken teeth at worst. It is only evident in about 1/3 of the gear and only on some of those, as the other 2/3 was in fluid.
This is a very expensive gear and this shop doesn't cut corners, but I'd like to know that it's necessary before coughing up this kind of money, with seals bearings etc I'm around $700 plus labor.
and more importantly the part shown in VB is for 71-73, Nigel's site requires a call for this year, TRF's site is just too much work to find anything and BPNW (my preferred as they are a sponsor) doesn't get that deep into these type parts. Does anyone have experience at this level, can I even use the VB part?
Thanks,
Mike
Thanks,
Mike
Hi Guest!
