69 Sprite drum brake adjuster
Upland
I had my drums off the other day and for the life of me I couldn't figure out how to move the adjuster to loosen or tighten the pads. How does that work?
Upland
JPSmit
If you look at the pic you will see that the adjuster (threaded part) works like a wedge pushing the pad further apart.
More instructions here, but basically (from the back) you wind it in until the hub no longer turns then wind it back until it just does.
http://www.spridgetguru.com/TA0045.html
It is also worth (eventually) buying a brake wrench for this - not expensive and so much easier.
Jim_Gruber
Wind it in until yiu hear the shoes just barely start to scrape when you rotate the wheels than back off a smidgeon. Oh and BTW - if this car has set for a long time, chances are this adjuster may be frozen up. Some heat and PB Blaster will help to gt it unstuck. A 1/4" or 3/8" wrench is needed. Easy to round off the square head so use the correct wrench. And I swear I one of these on one LBC that had a metric square head on it.
glemon
I will second the rusted on, and that was my first thought when I read the original post. How does this thing work since nothing seems to want to move. Yeah, heat and PBBlaster, I seem to recall Spridget adjusters being bad offenders for getting corroded on. Is also easy to round the corners if stuck or the wrench doesn't fit right.
Jim_Gruber
Keep with PB Blaster for several days, keep applying, “Patience Grasshopper” or your will totally F it up. Several more days of PB Blaster or whoever is your favorite deruster and then get out the propane torch. That will likely fix it. Oh and order 2 new adjusting screws.
Upland
Upland
All your info was really helpful, I'm kinda embarrassed to say I was thinking it adjusted from the front of the plate, and couldn't figure out how to move it!
JPSmit
we've all made those kind of assumptions - which is why this forum is so great - we all remember when we were new (mostly :smile: ) in the answering of questions.
:cheers:
nomad
When working on a car with an offending adjuster and other brake work that needs doing i take those adjusters out and clean everything really well before re-assembling them with Never seize. A Liberal coating and you never have trouble again.
M Brake Drum Help - 60 Sprite Spridgets 88
Z Adjusting Rear Drum Brakes 64' Sprite Spridgets 9
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 6
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
CARSINC Progress On My 1965 Sprite (update) Spridgets 3
Bayless Onslo the Sprite runs Spridgets 4
F Sprite Gearbox Spridgets 5
CARSINC Sprite bonnet emblems Spridgets 4
George Zeck SOLD!! 1964 AH Sprite MKII Spridgets Classified 0
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
drooartz A disassembled sprite takes up a lot of space! Spridgets 30
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
CARSINC For Sale Sprite Differential Spridgets Classified 0
CARSINC For Sale AH Sprite Axles and Hubs Spridgets Classified 0
Bayless What size battery for my '67 Sprite? Spridgets 5
CARSINC 1965 Sprite Bugeye Spridgets 5
CARSINC Sprite Electrical System Information Spridgets 2
Boink 3D Sprite Model Spridgets 3
A Sprite Tacho Spridgets 2
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
S Calling All Spridget Owners & Race Fans - Sprite Turns 65 Spridgets 3
Bayless How does '67 Sprite top attach to body? Spridgets 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D Whitworth on 59 Sprite. Spridgets 11
N For Sale Austin Healey Frogeye Sprite Spridgets Classified 0
D Sprite Model Identification Austin Healey 2
S Sprite Fuel Pump Upgrade Austin Healey 1
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
Bayless My primrose Sprite Spridgets 3
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
Bayless A Sprite gets some paint finally Spridgets 2
N Sprite "Ribcase" Transmission Austin Healey 3
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
tr6nitjulius For Sale 1967 Austin Healey Sprite Mark 111 Spridgets Classified 0
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
SD Bugeye For Sale 59 sprite Spridgets Classified 9
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
Editor_Reid FIRST Sprite For Sale Spridgets 1
lbcspinners New article today from Hagerty Media: the Austin-Healey Sprite Austin Healey 0
equiprx BUG EYE SPRITE, One of a kind print, Signed by the photographer Austin Healey Classifieds 0
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
