Hi, After almost 10 years owning my car, and having it run great, this year it doesn't want to cooperate. It starts and idles great but lugs/sputters whenever I try to accelerate out on the road. Distributor is relatively new, new plugs, wires, coil. Carbs are immaculate. The only thing different this year from any other is that this past winter I rolled the car out of the garage in order to do some work in the garage and didn't get a chance to get the car back in (but it was covered). So the car was subjected to about 2 months of very cold weather - if that makes a difference. The only other thing is that if I take the vacuum hose off the carb that goes to the vacuum advance on the distributor and blow into it, there is no resistance and I hear air 'leaking' (the hose is in good shape). Also, if I take the hose off while the car is idling, there is no change in the engine idle. Does that mean the diaphragm (I'm assuming that is what's in it) is broken? Thanks for any help. Jim
