'69 E-Type sputters, coughs & dies
DJames
Finally got a nice weather forecast last week and decided to go for a ride. Car started normally, pulled out of the garage, shut it down, made ready to leave, restarted normally and got about a block from the house and it started to cough and sputter and died. Tried restarting and it tries to run for 10 seconds or so and dies. Luckily a neighbor with a tow strap pulled us back home. Living in the Midwest, I pretty much put the car away in the winter and this year we went straight from winter to the lower 90 degrees in May. I try to run the car around the block once a month or so but it hasn't had a several hour long trip in a while. Given that recent history I shouldn't have been shocked when I discovered I had last bought gas in September of last year (complete with a treatment of Sta Bil). Given the age of the gas I wonder if first I should drain the tank and refill with fresh. I was telling this yesterday to a friend who owns a couple of Corvettes and he suggested I try pouring in a treatment of Sea Foam before I to drain it all out. Has anyone have knowledge of Sea Foam (I have never heard of it), and an opinion on whether that is a good idea or bad idea or do you think the bad gas idea is completely off the mark.
Thanks,
dj
TimK
I have a similar pattern of use for my Austin Healey, but I try to run at least 10 miles each time I take it out. I’ve never had any problem with fuel purchased late summer last year and treated with Stabil. If you are doing infrequent very short trips, you may be accumulating condensation and carbon build up. I don’t have a solution for getting the car running again, but once you do, I’d recommend longer trips and some hard acceleration. Have you checked the spark plugs for fouling?
Deleted member 8987
Thanks,
dj
well.....the description is not broad enough to adequately discern the issue fully.
However....I would be looking at a fuel filter (if one is installed other than the sediment bowl), and remove the sediment bowl, look for water (big problem with ethanol based fuels), then disconnect a line, key on, and pump into a container, looking for A) adequate fuel flow and B) and water in said container.
And remove the petrol tank cap....in case you're sucking a vacuum.
Lack of adequate flow...rubber hose.....electric pump perishing....garbage in the tank plugging the inlet.....but before you dump it all, do that and if you have a replacement drain on the tank with the small drain plug in the middle, try that to see if water/separated ethanol.
Geo Hahn
Could also be a stuck needle valve preventing the fuel bowl(s) from filling. You should be able to see fuel getting sucked into the intake with the air cleaner plenum off and looking into the throats of the carbs.
If one or two are stuck sometimes a sharp rap with a piece of wood (e.g. a 2x2) will jolt them loose, worst cases require dropping the fuel bowl(s). Pretty easy on the rear carb, more of a pain for the front carb.
Deleted member 8987
Twin Strombergs unless swapped out for three SU's, right?
Chance both needles stuck shut are little...not quite none.
One stuck wouldn't cause the engine to fully die....just shake and roll.
Gotta remember with Limey Limos, if you think it's fuel, it's ignition..if you think it's ignition, it's fuel.
LarryK
Get some spray carb cleaner, not injector cleaner. take tops off carbs and spray. Check for oil in damper of carb. Check filter. Put carbs together, start and spray cleaner into carbs. Watch for backfire. Check plugs for fouling\black for rich and or wet. I would change them. Also, check exhaust for mice trails. I have started a lot of sitting Jags that had mice nests in the exhaust. I used to work for JustJags in Maplewood in the early 90s. Any problems, check my profile for ways to get in touch. I'm across the river from S. County half way between Columbia, IL and Belleville. Have Jag on a cart, Valiant on jack stands. Do have some used ignition stuff we took off show cars to put new dress up items.
DJames
Well, I decided to try the easy thing first. I have drained the tank,fuel line to the filter and the filter bowl. There is a small slotted plug in the center of the bottom of the Stromberg carbs. Is that just a threaded plug that would drain gas from the carbs or is it some kind adjustment device I should not mess with?
Thanks
sj
LarryK
Take top off carbs, pull dampers out, check diaphragms for cracks, check for oil in top of damper. Spray carb out. Go from top of housing on strombergs and clean floats and check valves, if SU pull top off fuel bowl on side of carb and check floats and spray out. If it runs, possibility of low oil in damper. Bottom on the stromberg is a sealed adjustment. Recheck plugs, make sure they are clean.
LarryK
How are you doing on carbs?
DJames
Just got back in town an hour ago. Went up to Milwaukee to visit friends. It just also happened to be the 115th birthday celebration of Harley Davidson up there. LOTS of Harleys up there and on the hiways. Hope to know if the gas was my problem by the end of the week.
dj
LarryK
I rebuilt a MK V11 engine for a friend. He put petronix ignition on it and had fuel like problems. Boiled down to needing the petronix plug wires. Just a thought.
mwagon
Hi,
did you here the fuel pump working even after dieing? Is there fuel in the fuel bowls? If not could also be block fuel bowl venting
LarryK
Any progress here?
DJames
Hi Larry,
Well, I drained and refilled the tank and lines, changed the fuel filter to no avail. Took the tops off the carbs, checked for anything sticking and inspected the diaphragms for any tears with no improvement. Pulled all plugs, nothing looked unusual to me, made sure the plug wires were making firm contact at both ends, no help. Noticed that when I tried to start, it seemed to run correctly for a few seconds and then starts to choke so I thought just maybe the fuel pump was no longer supplying enough pressure to keep up with the carbs once they started asking for supply. Had a spare pump in the trunk so I change it out but no help. I really don’t have the tools nor the confidence to start fooling with the ignition, distributor etc so I have made arrangements to have the car hauled over to LeStable next week. Will reply with the findings when I get them.
LarryK
Sorry you have to send it out. Seems like you don't really have the time to dig in. I don't think I could get it on my trailer. I have been working on them since 1965. Dad had a dealer bring home a 57 140 Coupe, wouldn't shut off. They left it running in the driveway and Dad drove into the garage and pulled the wires. Mom and Dad took off to Indiana and I wired it and drove it to school the next day on learner's permit. Have carb kits for everything. I have heard of LeStable, I worked at JustJags 90-92. Rebuilt a MKV11 3.4 couple years ago, after a friend picked it up from an engine shop all screwed up. Spent thousands of $ and I re-rebuilt it and transmission and carbs for $750 in parts. No labor, he had already been screwed, needed him to enjoy the car not hate it. Not much harder to work on than a Chrysler slant 6, just more bolts and nuts. Let me know what they find. Once running, I am over the river, thru Columbia and then to Millstadt, fried fish Fridays in town. Good luck.
DJames
Well, I was pretty sure it wasn't an "air" problem and felt I had eliminated a "fuel" problem so of course it was a "spark" problem which I know little about. Apparently it was mostly distributor related, burnt points and a bad condenser(?) along with slight adjustment of some kind to the carbs. Suppose to be running like a top now.
LarryK
Good to know. Hopefully you will get some decent days to drive before stabilizing for the winter. Ever drive over the river to Il, come up from Columbia to Belleville, Millstadt is halfway to Belleville. Fish stand open on Fri and Sat. I'm two blocks from stop light intersection and fish stand.
DJames
Cool, we have been your direction a time or two in the past. Been to a German place a bit farther south for lunch once and stopped in at Gallagher's once. We are North County so our areas couldn't hardly be farther apart and still be in the same metro area.
LarryK
I had assumed South County. Is a ways to go.
D 69 E-Type sputters when making left hand turn Jaguar 6
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
M Series 3 E-Type Bonnet Jaguar Classifieds 0
Basil The new Kia E-Type? Jaguar 6
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
I GT6 A type OD vs D type - engagement speed? Triumph 3
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
VooDooDaddy63 Basic E-Type Question: Fasteners - Metric or SAE or ...? Jaguar 15
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
S For Sale Lotus Elan Factory Workshop Manual on CD/ROM - Type 26 - 1963 - 1965 Other British Classifieds 0
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
AH67 Heat Shield finish 66 Type Jaguar 5
AUSMHLY Grease type for zerk fittings Austin Healey 7
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
M 5-speed, 1968, 4.2, E-Type, OTS Jaguar 3
M e-type siries 1.5 shock abosorbers Jaguar 3
B TR2/3/3A 'A' type Front calipers, TR3 vendor??? Triumph 7
M E Type 4.2 engine rebuild Jaguar 4
D E-Type steering wheel Jaguar 6
DrEntropy E-Type windshield FYI: Jaguar 1
TRclassic3 TR4/4A A type OD working in 3rd but not in 4th Triumph 5
Graham H TR2/3/3A A type overdrive Triumph 6
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
M E-type series 1 plastic dash vents Jaguar 1
M TR2/3/3A SU H Type Carberator Float Lever Adjustment Triumph 10
KVH General TR Type A Laycock Overdrive Questions Triumph 8
Talon TR2/3/3A Float lever issue on SU type H carbs Triumph 1
Boink Left-hand Drive E-type at Windsor Jaguar 5
H Clutch-Type Differential Austin Healey 5
M Brass F type radiator shell build Restoration & Tools 11
NutmegCT Type L SU fuel pump Austin Healey 8
Basil Terrible way to spot an E-type Spotted 4
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
J TR4/4A TR4 A Type Overdrive Part mixup Triumph 4
55modified Radiator sensor thread type size needed for bn1 Austin Healey 12
PC X-type shooting brake Spotted 0
J MGB 1974 1/2 MGB gasoline type MG 5
Jim_Gruber Non LBC but saw my first Civic Type R Yesterday Spridgets 24
M S1 e type radio console Jaguar 2
Basil E-Type fuel tank mounting bolts [$&^##$%*!!] Jaguar 16
CJD TR2/3/3A A type Overdrive Seal Triumph 9
