bcliff
I'm working on a 69 roadster. I pulled the steering column apart today. It seem to have some parts that are not in the haynes manual. It has ball bearings at both ends. No nylon bushings or felt seals. I have done an earlier steering column and it was not like this. Is a 69 an oddball, or are the later columns like this too? Also, I removed the lock cylinder to have it keyed, and there doesn't appear to be anything that locks the steering from being turned. Is there supposed to be something? There is no indication that the column has been taken apart before. Here is a picture of the loveley beast when it came home. It was media blasted, but has been outside. Fortunately the northern Colorado weather is pretty dry, so you are seeing just surface rust. The floor is beautiful as are the sills. There was a tiny bit of rust in the rear dogleg, but just in the surface skin. It will be approachin paintable condition by the end of the day,5/18.
Bruce
Bruce
