'68 Sprite Wiring Diagram Needed
Jim_Gruber
Anyone got a PDF for the Wiring Diagram on a '68 Sprite. My folder with all of my wiring diagrams is MIA when I need it. I've got front signal issues I can't figure out without one.
Found it. Never Mind TIA
Found the issue after I chased a bad ground all over the car. Finally found in the ground wire that attaches to the inner fender. Cleaned everything up with a Dremel and retapped the hole, still not having any luck. Ended up running an additional ground wire to that spot and all of the gremlins went away immediately.
