Lynn Kirkpatrick
So, I'm driving along in my '68 MGBGT with a '74 motor, all warmed up after 20 miles, and I notice the oil pressure seems to vary. I realize/expect that at idle the pressure will be around 25 psi. But at steady speed (40-50 mph, 2-3000 rpm) I can see the needle float between 20-30 psi. If I liftoff the throttle the pressure rises momentarily, then drops to 25. When cold, the pressure is 60-75 psi.
It has a pressure sending unit, not a pressure switch, the two choices in the Moss catalog. I have cleaned the connection on the sending unit, but haven't driven it to see if that helped.
Any other suggestions?
Lynn
Lynn
Hi Guest!
